RE: Pulling Banners?
I made and pulled one with my Great planes Tri-plane. It read, "Pattern Sucks!" The pattern flyers at the field got a laugh, and said it was ok because they knew better. I DO NOT recomend the Tri-plane to pull banners. And make sure it is attached to the center line of the aircraft. even just a bit off line and it pulls hard to that side. I was glad I knew how to use a rudder. Jeff
