RE: is this right????????????
i took out the rear drive shaft on the passenger side and spun the axle and it spun with some resistance. i did the same thing on the drivers side and it spun just fine. is the bearing going bad??? if so how do i get the axle out? i took the two set screws out of the rim nut but the axle would not come out.
