RESOLVED
,I bent the single-piece starboard trim tab (inside edge closest to keel) about 1\8" down to offset the forces that be,because I'm always on the throttle,ride attitude to port side is minimally minimal [:-] ,I will be adj. prop angle back to even with the keel as i was runnin "wet",and try to regain some lost (drag-induced) WOT speed and still retain stability,yeah, there's a fine line there............[:-] thank-you to those that responded...
