RCU Forums - View Single Post - SYSTEM3000 Beginner's question
Old 01-29-2007 | 09:29 PM
  #41
shd3920
Default RE: SYSTEM3000 Beginner's question
Point I was going to make to him bruce. I thought it was the LT-40 that the problem was with but I was wrong, it is perfect. The problem as it turns out was the Senioritta. I looked at the setup there and found out that the servos were linked up wrong and THAT was the airplane that the elevator and rudder were on the right stick (I knew there was a plane that was set up that way). I have since corrected the linkup and it is now correct. I have still got some jerking in the servos as mentioned earlier and I am still working on it. Will get back to you if I can not figure it out. Thank you.
I understand that the antenna has to be uncoiled but I only plugged the servos into the receiver of the Tower Trainer to install the servos.
I assure you that is not the reason for the servo frenzy. The antenna is attached at the fin.
ORIGINAL: bruce88123
Ken, wrong plane. Picture is of the Tower trainer. Problem is the LT-40. Good point though.
