RE: KYOSHO JET STREAM GP 10
chyea thank you, lastnight i tore everything down, cut m shaft about 6inchs and turns out, i deen a u joint or coupler, the notch in the shaft is all it takes, i added a grub screw to the nut off the engine though, i'll post some pics
