ORIGINAL: bzinfinity
No problem - one other thing now that I think about it.
If you increase the servo speed in Clearview, see if you can edit the throttle and pitch curves and tell me what they are.
Clearview is on my Laptop which is at work right now, so I can't check the screens myself. Although I just had an idea to get the Clearview Pro performing correctly.
Hey BZ,
Here are the pro's pitch curves in Clearview:
pitchCurve1 -3.0 -1.5 0.0 1.5 4.0
pitchCurve2 -3.0 -1.5 0.0 1.5 4.0
Did you figure out what it was that might get it performing correctly? Also, I don't see anything called 'servo speed' per se . Is there anything else it might be called?
Ed
