ORIGINAL: Rocketman612
ORIGINAL: OverTheEdge
I did decide on the Saito 82 for power and I just got it today!
Wow the saito 82 will match your RCU name LOL. Prop clearence will be an issue. Did you get larger wheels ?
I'm using an Irvine 53 with a 12x6 APC and larger wheels I have just enough clearence.
Pete
Nope... but I don't use the stock landing gear. If you look in my gallery you'll see my last SSE with a Dubro main gear... I'm using that same gear on this SSE. I checked for clearence and it seems that a 14" prop should be no problem (might get a little green custom dye on the prop from time to time depending on how freshly mowed our flying field is [8D])
