RCU Forums - View Single Post - Genesis alloy Clutch Engagment?
Old 02-06-2007, 01:58 PM
.46NitroAddict
Default RE: Genesis alloy Clutch Engagment?
One would assume that if you used a heavier clutch shoe with the same springs that you would get engagement at an lower rpm. Due to the fact the the centrifical forces on the clutch shoes & springs would be more, causing the earlier engagement.
Simmilarly a lighter shoe with the same spring would mean a higher rpm engagement.
I say this in theory only, as I havn't tried it in practice yet,
.46NitroAddict [>:]
