RCU Forums - View Single Post - Good Radio's?
Thread: Good Radio's?
Old 02-09-2003 | 03:07 AM
MikeL
Default Good Radio's?
Originally posted by david a
If I buy a Hitec Laser 6 with a flight pack and the frequency for the radio and reciever is 53, can I buy additional Hitec flight packs at the same time with the additional receivers also set to frequency 53? Will I be able to use the Laser 6 with these additional receivers since they are both on frequency 53?
You sure can, but there's where one of the real advantages of a computer radio becomes clear. Instead of manually re-adjusting your trims and servo-reversing, you just pick the other model from the computer radio's memory. It's very simple, and saves both time and hassle. Some folks will say that it's easy to forget to switch models, but the converse is that it's just as easy to forget to reverse a servo.
If my receiver goes out will I have to throw the radio away and buy a new one?
Nope.
