Old 02-12-2007, 08:12 PM
HDB
Default RE: ENYA MANUALS & PROPS
Thanks Jaka, finally found out, as you said, to begin with a 14x6 and go from there on the prop --- However, on the Enya 90(at least this one!) the prop shaft is only 5/8 inch long, not long enough for a prop, prop washer and even a prop nut of any kind. When measuring prop shafts on Saito, OS, etc the shaft is over an inch long with plenty of room for a heavy nut or what ever is needed. The nut(with a sleeve) and prop washer that came with the motor will work, but I need larger nut in order to use an electric started well.
Any One with any info on this please?
