RE: rich model keecat.60 size kingcat with retracts
Sure, do it all the time. Just set the travel adjustment of the 2nd servo to zero in both directons. That way no switch or knob can work that servo. Then mix that servo to the primary control servo. It depends on the radio and on which mix your using, if it will trim along with the primary servo.
