RE: rich model keecat.60 size kingcat with retracts
My CG is approx 8.5" from the trailing edge of the wing measured against the fuselage. It will probably end up around 8.75 to 9.0 when I get it perfectly balanced but as I said I'm very close to dropping the dime on a turbine for it which is .37 lbs heavier than the OS 91 w/ muffler so that will probably move even further foreward.
