RE: Yellow F-15 ARF Assembly Thread
Craig - thanks for the answer. I bought the std tanks from Yellow, they were $90, the Jet Tech pair is $180. I have seen several other F15's with the Jet Tech's - guess its up to you. I was thinking to make the front gear install easier (and removal if necessary) to use the 6-32 w/blind nuts on the front and then use 6-32 bolts w/nylon insert lock nuts facing in the opposite direction for the rear ones. They could be taken out from inside the fuse instead of painfully from the bottom a 1/4 turn at a time. Anyone else doing this?
