RE: MRC Super Brain 989
The 1.2c maximum charge rate for LiPos is hard-coded into the charger. You have to input the storage capacity of the battery into the charger and the 1.2c charge cap is based off this data. I was able to select 19990mah for maximum capacity for a 3-cell LiPo and then select 10.0 amps for charge rate. If you want to charge faster than 1.2c, you'll need to input an exaggerated battery capacity to get the charge rate you want.
