RE: Taurus LE
Mred;
I have thought about that, it's the same method used on the "Bingo" but wasn't sure that I wanted to because of the 19% airfoil makes the angle quit steep and would have to use 1/2" square.
Thank you for your input, this is the best solution so far but as I said above I may just use the wrapped LE and reinforce it with a carbon fiber arrow shaft. I did this on an electric I built and it was very strong and light.
