Old 02-17-2007, 12:21 PM
Deadeye
Deadeye's Avatar
Default RE: u can do 46 firewall & scratch build
2 or 3 degrees of right thrust is usually the rule. If you plan on swinging a large low pitch prop with the Saito, I'd go 3 degrees. I use vibration isolation mounts on all my four strokes, and the thrust can be fine tuned with these types of mounts.
