Old 02-19-2007, 01:41 PM
firstplaceaviator
My Feedback: (27)
firstplaceaviator's Avatar
Default RE: Wall Charger Question...
In order to charge a 14.4 V pack, you will need a charger that puts puts out 16.0-18.0 volts, otherwise the batteries will not receive a full charge. Since you have 3300 Mah packs, you can charge them with a 1200 Mah charger in about eight hours or quick charge them at 5 amps. There are several wall chargers that would do the job. Personally, I would charge them individually with an R/C car battery charger. They are not very expensive (Tower Hobbies model 420 is only $30.00) and you could charge both packs in about three hours.
Doug
