Channels for separate Rudder and nose gear servos
I recently purchased a Great Planes Giant Stik and I am going to use a Glow engine and a tricycle landing gear configuration. I am using a servo for the rudder mounted in the top of fusalage in front of the horizonal stab. I am using a separate servo for the nose wheel mounted in the cockpit area. I need to know how to hook up each servo so the nose wheel and the rudder will work in unison. I am using a Futaba 7Cap radio with a Futaba R-168DF receiver. I know that with the futaba receiver channel 4 is used for the rudder when a single servo is used for both but not sure which channel to use for the nose gear when separate servos are used. Will a Y harness work or am I going to have to plug into two channels and if so, which two channels. Any help would be appreciated.
