RCU Forums - View Single Post - Calculating CG
Thread: Calculating CG
Old 03-12-2002, 07:44 PM
hauckf
Default Calculating CG
Posted this same question on another website and got this answer. Haven't tried it, but it sounds logical. "Find the MAC of the top wing and the bottom wing. Draw both MAC's in the side view. Draw a line from 25% of the top wing's MAC to 25% of the bottom wing's MAC. Divide the last line into two segments. The top segment length is proportional to the area of the bottom wing, and the bottom segment length is proportional to the area of the top wing. The point that is between the two segments is the aerodynamic center of the top and bottom wing together. Put your CG there to start with, and move it back in small increments between test flights until the desired reduction in stability is obtained." Good luck!
