ORIGINAL: sinergy
Yes this is correct... thread lock all servos if they are metal gear servos (and they should be) Also DO NOT use Karbonite gear servos. Balance your prop and make sure everything is tight. Loctite the engine bolts as well.
What's wrong with Karbonite gears?
TIA,
CR
