RCU Forums - View Single Post - Blade hang angle
Old 02-10-2003 | 08:51 PM
DICKEYBIRD's Avatar
DICKEYBIRD
Default Blade hang angle
OK, I got the blades carved for my small homebuilt gyro project and am now working on the hub....a poly "flapper" with 15 deg. delta hinging. Does any one know the pros & cons of blade travel limits? Do the blades ever need travel downwards past zero coning angle ie: droop down below the hub at all? What about upwards travel limitation?
Thanks for any thoughts on this subject.
