RCU Forums - View Single Post - Interesting Hover problem
Old 02-28-2007 | 10:47 PM
alienteabagger
Default RE: Interesting Hover problem
YES!!! This is exactly what its doing!!!!!
So I guess I need to work more on 'anticipating' which way the heli is about to go so I can correct accordingly? Is there anyway to get the heli itself to respond quicker to control inputs (besides getting better servos which Im ordering now). It does seem to have a delay between when I move the stick(s) and the heli responds.
ORIGINAL: PilotLight
Try getting on the collective faster and practice for a bit. If the problem still exists, get some video so we can see what's happening.
It will "swing" and go up and down as you are practicing hovering if you are behind on the corrections. I call it the toilet bowl effect. It can start going in circles and gets higher around the edges of your flying area. As the heli is moving through the air and you try to correct it, when you pull the leading edge of the rotating main disc up, it will tend to climb unless you reduce collective. For example; the heli is going forward away from you, you pull back on the cyclic, the heli will pitch nose up, climb, stop forward motion then start going backwards and descending. Now you push forward cyclic and rear of heli goes up, heli climbs, tilts nose down and starts descending and moving forward all over again. Low in the middle and high at the edges. You just have to adjust faster both collective and cyclic.
