RE: Safely Removing Dried CA from Covering
G'day Mate,
Mix a small amount of acetone, with some toothpaste, & start rubbing gently, the toothpaste is a very fine abrasive, it will remove the CA without damage.
May be best to test the mixture on a part that can't be seen to make sure no damage is done to the covering.
