RE: EXTRA 300 THRUST
Standing behind plane, you want the engine to angle to the right 2 degrees(two thin washers under front two engine mounting holes).
Most ARF'S come with built in right thrust. No up angle. Your cg must not be correct if it noses over real easy. As you taxi, you must hold full up elevator to help keep tail down and better tail wheel steering.
