RCU Forums - View Single Post - Team OMP Presents the Boxxer ARF!
Thread
03-06-2007, 09:08 AM
5
TailTwister
My Feedback: (
1
RE: Team OMP Presents the Boxxer ARF!
Hinge the Elevator to the Stab:
1: To make this as easy as possible, the 4 hinge locations are pre slotted for you from the factory. Simply slide all hinges into place, checking from top and bottom that none of the hinges have missed the precut slots. After you are content that all hinges are centered in place, flex the elevator at the hinge, just beyond the amount of throw you intend to use for full 3D throws. Add thin CA to the top of the hinge, one drop at a time. Pause between drops for a second to allow the CA to wick into the wood. Five to six drops of CA per hinge is usually enough. Wait a few moments, and then repeat this process to the bottom of each hinge. Never use CA kicker on a hinge. If any CA runs over your covering, it can be removed with Acetone, or fingernail polish remover. Use either sparingly.
Reply
Like
TailTwister
View Public Profile
Send a private message to TailTwister
Find More Posts by TailTwister
View iTrader Profile
