Old 03-07-2007, 06:33 PM
aerowoof
Default RE: AUX batterie?
glow engines do not need a battery to keep them running once started if you keep having flame outs at any setting other than idle then there is a problem in your set up and using a glow driver to fix it only mask the pr5oblem with out curing it.I have seen alot of post lately refering to glow drivers and am wondering if it is the current fad or rookies that do not know how to run glow engines.any inverted engine may benifit at idle with a glow driver to help from flooding out with a mixture that is set to rich 2 strokes used to use an idle bar plug to help eliminate flame outs.after looking at the plug offerings lately they are not as abundant as in years past.
