RCU Forums - View Single Post - Interesting Hover problem
Old 03-08-2007 | 04:15 PM
Heliko's Avatar
Heliko
Default RE: Interesting Hover problem
Alien, I was just watching your second vid and it seems your blades are way too loose. If there not tight enough they won't track correctly causing vibration and uneven lift. If the blades aren't thick enough for the grips I would shim them with washers. Tightening up the blades and retracking them should yield a noticable difference in stability.
