RCU Forums - View Single Post - Mounting the ignition module
Old 03-08-2007 | 11:13 PM
Tired Old Man
Default RE: Mounting the ignition module
I believe the engine he is using has an ignition very similar to, if not actually being, a CH. If so, then the method krayzc noted is just fine. If it's a 3W or Falkon type then it will need some room for air to blow under and around it as noted by AirWizard.
