RE: Flying Wing
OK... Finally got it all worked out.. Combat Wing XE2.. added the three (3) additional CF spars, upgraded to MEGA 16/15/3, using the APC 6X5.5 right now.. will check the current with a watt meter soon, but so far temps seem ok.. but boy does it rock.. I would say at least double the performance over the stock speed 400 set up.
Now I'm out looking to switch to LIPO for some more boost. I picked up a bunch of APC props 6X5.5, 6X4, and a 5X5 from nesail (they are right down the road). SO I can play around a bit.. but so far what I'm using seems very fast. No flutter .. but only had 1 flight so far.. wing is awsome ripping by on a low pass.. down right dangerous now.. thanks for all you advise and help..
On another note I joined the local club and bought a used Hobbico Nexstar.. now just need the snow to melt and the field to dry out.. in the meantime the wing will go whenever the weather cooperates...
