Old 03-09-2007, 02:41 PM
BillyGoat
Default RE: Hitec Laser 6 and H9 Ultra stick 60
To answer you last question first. Just rewiring the Y harness won’t work you need to purchase a reversing Y harness.
For your ailerons I say forget a Y harness and plug the left servo into ch 6 and the right into ch 1. The manual will tell you exactly how to slave ch 6 off ch 1.
For the flaps a standard Y should work fine. Put the linkages on the same sides of the servo. If one is toward the inboard the other will need toward outboard.
