ORIGINAL: flyfisher431
correction the Ailerons will work correctly it's the flaps that won't. Proof read Ben Proof read[:-]
Since the Laser 6 is not a computerized TX, you have to leave the ailerons the way you have them. Channel 5 is gear and 6 is flaps.
For the flaps, it's simplest to use a reversing "Y" or flip one servo arm 180 degrees.
