RCU Forums - View Single Post - New Plane Set-up
Old 03-09-2007 | 09:41 PM
painchaudd
Default New Plane Set-up
I just ordered a Funtana X100 and am starting to piece together the parts to make it fly. Has anyone used the Saito 100 in this plane (to keep within my budget), or should I get the 125 to make sure to have enough power? How about a 2 stroker (much cheaper)? With a big enough prop, will the 2 stroke work well? Is the only downfall the large oil mess I have to clean up after running it?
I am also building a new radio setup on a budget. I will be using the Jrxp6102 radio with a R600 receiver. Is it ok to use Hitec servos with the Jr radio and receiver (since Hitec servos seem to be a little cheaper)? I am also wondering if you can mix and match digital and standard servos on the same receiver as well? I have never really messed around with mixing and matching components, but it looks like many other people are having success doing it.
Thanks for any advice you have!
