RCU Forums - View Single Post - Broken ring, why?
Old 03-10-2007 | 04:52 PM
pe reivers
Default RE: Broken ring, why?
Greg,
Can you make a detail picture of the ring and piston? It looks like a piece of the ring damaged the piston.
MVVS cylinders are ground, not honed, so you just need a new ring. If the bottom ring land has no damage the piston probably can be used as is.
