RE: Gasoline fuel to glow fuel tank set up question
You will need to replumb it. If I am not mistaken, I believe the Tygon is attacked by the glow fuel. I know gasoline attacks the silicon fuel line used for glow engines. You will need to replace the stopper on the fuel tank as well. Replace the fuel line and clean out the tank. I can't believe that it will cost more than $10-15 for everything for the conversion. I recently replaced the fuel line on my glow plane and 4 feet of fuel line was only about $4 or $5 (maybe less).
Hope this helps.
