Old 03-17-2007, 09:39 AM
exeter_acres
exeter_acres's Avatar
Default RE: Uneven servos
could be a few things... but it is probably just the difference in servos....
ditch the "Y" (they are evil and bad) and use a seperate channel for each servo, then you can set end points seperatly...
and I think you can even adjust the speeds on the 9303 (not sure on that one as I fly Footooboo)
