RCU Forums - View Single Post - QUICK FESTO QUESTION
Old 03-20-2007 | 04:20 AM
davo580
Default RE: QUICK FESTO QUESTION
inside a festo fitting is a o'ring. make sure the tubing is cut square and has no nics or barbs or will damage the o'ring. give the end of the tube a good dose of spit and it will go in easy.when you put the tube in you will feel the o'ring when you first push in just push a little further and it will fully inserted
