RCU Forums - View Single Post - Glassing help
Old 03-21-2007 | 07:23 PM
branded
My Feedback: (9)
Default RE: Glassing help
ORIGINAL: acerpal
I have a problem keeping the cloth down flat when I am glassing. I brush the cloth with a brush and it lays down fine. As i ork the resin in I get little waves.I have tried a sqeege and brush. I still get little waves in the cloth. As a result I get a very wavy finish which requies a lot of sanding What am I doing wrong?
I apologize if you already have your answer for I did not read the entire thread.
It sounds like to me that you're pulling the glass because you haven't adequately thinned your resin. The resin should be about the consistancy of milk, not much thicker.....It should take a very, very light stroke with a brush to wet out the glass. If you're having to press hard and swipe the brush hard to get the resin to spread then you're resin is too thick.
