RE: KMP Cessna Skymaster
Cg is 105 mm from the leading edge. The ailerons are are very small and I would recommend maximum available deflection that your setup will allow.
The elevator reacts pretty normal. 1/2 up and down with some expo to start. Be prepared to add up trim to the elevator on maiden. If you use flaps you will
need to mix in some up elevator. The biggest problem I faced with this plane was keeping the engines cool. I added baffles and it took care of the problems.
Good luck, it flys great...
Tom
