RCU Forums - View Single Post - Fliton AJ Extra
Old 03-24-2007, 01:32 AM
  #67
BoneDoc
BoneDoc's Avatar
Default RE: Fliton AJ Extra
Thanks 3DAP,
Unfortunately I don't use X40, but go with these settings. Brake off, auto timing, 3S voltage cutoff (I use a timer instead. The last thing you want is a deadstick). You probably don't need the eyelet screws, but if that makes you feel more at ease when throwing the sticks around, then more power to you. If you're not planning on taking the wing off, then you can use zip ties. The CF rods for the firewall is probably not needed for a fresh motor box. On my AJX #2 (first one I lost due to radio failure), I didn't reinforce the box at all. I figure that I'll make it the sacrificial lamb and during the rebuild, I'll add the CF rods later. If you already did it, though, it'll be just fine.
The way you set the programming is to plug everything in with the throttle at full up. Then when you get the right beep, pull the throttle down to zero.
