RCU Forums - View Single Post - Problem getting front landing gear to fit in Jet Hangar A-7
Old 03-26-2007, 07:28 AM
jwsp69
Default RE: Problem getting front landing gear to fit in Jet Hangar A-7
Hi Mike..
Can you take a pic of the area u did the carbon on the nose?
ORIGINAL: mikedenilin
I have the same problem when I installed it. I just leave the gear door off. The knee on the strut is too big so I would cut off a section of the gear doors so they can close completely. I am a sport flyer so it does not matter to me if the knee sticks out a bit. By the way, do you have carbon fiber plate on the nose gear mounting? If not, I recommend you do so. I beefed up mine with Carbon fiber otherwise the nose gear will rip off if you have a less than perfect landing. This is the weakest part of this plane. After carbon fiber reinforcement, I can smash the A7 hard on the deck and can walk away with it.
Mike
