RCU Forums - View Single Post - edge,cap, extra, giles...what's the difference?
Old 02-18-2003 | 02:17 AM
OnTheEdge
Default edge,cap, extra, giles...what's the difference?
I agree with the others about the UCD 3D. However that's only if YOU have the determination to learn the basics and MASTER the basics before you attempt the wild maneuvers this plane is capable of. With the abilities of this plane with the appropriate engine, there will be A LOT of temptation to try the wild stuff before you learn how to get your ***** out of trouble. Also you would need a computer radio with the UCD and have someone set it up to mix out the rudder coupling this plane has while in knifedge. You could start with a standard radio and then eventually work into a PC radio with mixing and expo.
Best of luck!!..............Mark
