RCU Forums - View Single Post - Starter Problem
Old 03-27-2007, 03:01 PM
khodges
Default RE: Starter Problem
Is there enough room on the shaft to add a second nut to lock the first one? You could also try a star lockwasher, and put some threadlocker on the shaft when you tighten the nut down. Torque it good. I have used the same starter for a couple of years, starting a 41cc gas engine, never had the cone come loose.
