Originally posted by Geistware
It is probably the resolution of the camera that you are seeing as a low resolution image.
Actually, its the compression that is performed on the video. Even with a low res image, you can compress it to half its original size and get a very decent image. I checked the video format, and the artifacts you see are compression related, and not camera related.
