RE: KMP Cessna Skymaster
Hi...how do you balance this plane, do you pick it up from the wing tips, seems like they will not resist and break, can I use a CG machine???...it seems like the stops in the CG machine will just go through the balsa....
How are u guys balancing this plane???
Mine came un very heavy, haven´t put it on a scale yet, but I´m using and RCV 120 SP engine in front and a RCV 90 SP on the back...maybe this way I will not have to add too much lead up front, any suggestions / observations regarding this setup?...
thanks in advance for your collaboration
Javier
