Eddie,
I gave the wrong impression....I should have said that at 2900W, the output is about similar to the properly set-up 140/145 2 stroke output. The YS 140 sport is relatively anemic in comparison. The YS 160 is right there.
I still have a small supply of the K-Kord teflon covered kevlar but I haven't found it yet. Still unpacking.... a year and half later. I am going trough some boxes in the garage this weekend so if I find the stock, I'll let you know.
Do you know if the model is still available? I just can't seem to find time to get going on my new design so something for the interim could be good
Matt
ORIGINAL: swlarcham
Eddie, with the more aft CG the knife edge should have cleaned up....also the pull to canopy on verticals should have cleaned up as well.
I think so too. I haven't had a flight without stronger winds than I care to fly in so I'll need more trim flights to tell for sure. But a new plane talked me into flying anyway - And it handled it wonderfully.
Is this the Evo that's 400 bucks??
Yep !! I choked on the price for awhile but after watching Nat's Plett25-13 for 2 years I just couldn't go any other direction
And I don't regret it.
At 2900 watts you are pretty much same as fuel powered set-up in output...
I do know this -it is stronger than my YS140Sport by a lot. I haven't flown anything IC larger than that -so that's all I'm gonna say. I didn't put the wattmeter on it with the 21x13W and I should've as it was way stronger. -More than I'll ever need so why strain batteries and heat up the motor if I don't need to.
BTW Matt - do you still sell the coated kevlar pull-pull cord. If so I'd like to get some more.
Good to type with you.
Eddie
