servo mount bushing
I saw a tip on using an awl to insert servo bushings in the rubber grommets but found my Craftsman quick release drill bits work well and hold several bushings making the job quick and easy! Slip the bushings on the bit an push them into the grommets...also work with a jewelers screwdriver...
