Old 04-08-2007, 12:00 AM
alan0899
Default RE: Control Throw Recomendations - and CG
G'day Mate,
Try this calculator, http://www.palosrc.com/instructors/cg.htm
And the control throws, well I recommend, ailerons 3/4" up & down, on high rates, & set low rates to about 60%, elevators, about the same. Rudder 1" right & left.
First flight should be on low rates, & if you need more, you can switch to high rates.
If you do it this way it should be safe to fly & land, of course you can adjust later.
