Hi there if the props connected properley and the propshaft is connected 2 the motor well and the esc and rudder servo works and connected properley then charge you batterys and take it 4 a run just go slow and do a range test first! what type of transmitter is it?
Go slow and then build up speed and then reduce it slowley also dont do sharp turns!
Good Look!
JJ
