RE: Problem with HiTec Rx and/or crystal
It says: HFD-08RD DUAL CONVERSION * SHIFT SELECTABLE
On the side there's a label that shows the jumper positions (two left pins = HiTec/Futaba and two right pins = Airtronics/JR)
But as I said I get the same result no matter how I set the jumper loop. I've tried three different Sanwa crystals all with the same result. Initially it does seem like there is some kind of reception going on -- but it quickly becomes irratic and then the servos locks up.
