RCU Forums - View Single Post - no servo responce
Old 04-11-2007, 06:37 AM
rwright142
rwright142's Avatar
Default RE: no servo responce
You indicated you may have already done all of the following, but I'll list what I would do just in case.
1. First of all, what transmitter, receiver, and servos are you using? Do the servos move, but not the control surfaces?
2. Make sure all of the servos plug in to the receiver in the same direction (for example, all of servos should have the black wire facing the same direction.)
3. Take the throttle servo (you said it works) and plug it into the aileron channel (you indicated no movement on this servo) in the receiver. If the throttle servo moves then the problem is not the receiver. No worky = bad receiver since the throttle servo works in another channel.
4. Take the aileron servo (you indicated no movement on this servo) and plug it into the throttle channel (you said it works) in the receiver. If the servo moves then it is good. No worky = bad servo since the throttle servo works in that channel.
If the servos move but your control surfaces do not, see if you can move the surfaces by hand, using the push rods that connect to the servos.
Let us know the outcomes.
